Stainless Steel Spudger - Double Sided
Prying Tool
PRODUCT ID: 3434
Description
Is there something missing from your tool kit or workstation? Are you having trouble figuring out which
elusive tool it is that you're lacking? Perhaps it's a spudger! "A what?" A s-p-u-d-g-e-r! It's a prying tool
that has a wide flat-head screwdriver-like end that extends as a wedge, used to separate pressure-fit plastic
components without causing damage during separation.
Basically, this is the thing you should be using instead of a screwdriver, or your keys, or a knife, or
whatever you have lying around.
They're commonly used to open up slim electronics, for example replacing broken cell phone screens. One
of the ends is slightly pointed, so when applied to separate pressure-fit panels it helps to create an initial
gap before the wedge end is utilized. This is really a very very nice tool, once you have it, you'll use it all
the time for poking, prodding, prying, etc.
Features
o
o
o
o
o
o
Stainless steel metal, double-edged spudger / prying repair tool
Good for opening a wide range of devices, with minimal damage
Nice knurled handle for a good grip
Stainless steel build, very slick and strong!
Pointed prying end for better access to small gaps
Flat head prying end for wedging gaps open
Technical Details
o
o
o
o
Material: stainless steel
Length: 175mm
Diameter: 5mm
Weight: 18.5g
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3434 5‐5‐17
很抱歉,暂时无法提供与“3434”相匹配的价格&库存,您可以联系我们找货
