3449
3449
    ADAFRUIT
    LED 阵列 Opto 羽毛 平台评估扩展板
3449 数据手册
DotStar FeatherWing - 6 x 12 RGB LEDs PRODUCT ID: 3449 Description A Feather board without ambition is a Feather board without FeatherWings! This is the DotStar  FeatherWing, a 6x12 RGB LED Add‐on For All Feather Boards! Using our Feather Stacking  Headers or Feather Female Headers you can connect a FeatherWing on top or bottom of your Feather  board and make your Feather board strut like a peacock at a rave.  Put on your sunglasses before staring into these 72 configurable RGB LEDs, they are super bright!  Arranged in a 6x12 matrix, each 2mm by 2mm sized RGB pixel is individually addressable. Only two pins  are required to control all the LEDs. On the bottom we have jumpers for the Data and Clock lines so you  can change them from the defaults. Works with any/all of our Feathers! You can cut the default jumper  traces and use any pins you like  To make it easy to start, the LEDs are by default powered from either the USB power line or Battery  power line, whichever is higher. Two Schottky diodes are used to switch between the two. This power  arrangement is able to handle 1 Amp of constant current draw and maybe 2A peak, so not a good way  to make a flashlight. It's better for colorful effects. A power MOSFET is set up and connected to the  ENABLE pin on the Feather so that when the Feather is disabled, the wing will also cut power.  For more info on DotStar LEDs, including code examples and power calculations, check our our detailed  learning guide!  Technical Details  Product Dimensions: 50.0mm x 23.0mm x 3.5mm / 2.0" x 0.9" x 0.1"   Product Weight: 4.9g / 0.2oz        https://www.adafruit.com/product/3449 9‐15‐17
很抱歉,暂时无法提供与“3449”相匹配的价格&库存,您可以联系我们找货
