3458
3458
    ADAFRUIT
    Atmega328P Feather 328P AVR® ATmega AVR MCU 8-位 评估板 - 嵌入式
3458 数据手册
      Adafruit Feather 328P ‐ Atmega328P  3.3V @ 8 MHz  PRODUCT ID: 3458  With this Feather we're getting a little nostalgic for the ATmega328P ‐ the classic 'Arduino' chip ‐ with  this Adafruit Feather 328P running a 3.3V and 8 MHz. Feather is the new development board from  Adafruit, and like it's namesake it is thin, light, and lets you fly! We designed Feather to be a new  standard for portable microcontroller cores. We have other boards in the Feather family, check'em out  here.  At the Feather 328P's heart is an ATmega328P clocked at 8 MHz and at 3.3V logic, a chip setup we've  had tons of experience with as it's the same as the Pro Mini and similar to the Adafruit Metro 328. This  chip has 32K of flash and 2K of RAM, and we paired it with a SiLabs CP2104 to give it USB‐to‐Serial  program & debug capability built in. Works great when you want to keep your classic Arduino code  compatibility, but want to use one of our dozens of FeatherWings  To make it easy to use for portable projects, we added a connector for any of our 3.7V Lithium polymer  batteries and built in battery charging. You don't need a battery, it will run just fine straight from the  micro USB connector. But, if you do have a battery, you can take it on the go, then plug in the USB to  recharge. The Feather will automatically switch over to USB power when its available. We also tied the  battery thru a divider to an analog pin, so you can measure and monitor the battery voltage to detect  when you need a recharge.  Here's some handy specs!  o o o o o o o o o o o o o o o Measures 2.0" x 0.9" x 0.28" (51mm x 23mm x 8mm) without headers soldered in  Light as a (large?) feather ‐ 4.8 grams  ATmega328p @ 8MHz with 3.3V logic/power  3.3V regulator with 500mA peak current output  USB serial converter (CP2104) for USB bootloading and serial port debugging  You also get tons of pins ‐ 19 GPIO pins + 2 analog‐in‐only pins  Hardware I2C, hardware SPI support. For UART devices, should use SoftwareSerial  6 x PWM pins  8 x analog inputs (two are shared with I2C)  Built in 100mA lipoly charger with charging status indicator LED  Pin #13 red LED for general purpose blinking  Two LEDs for serial data RX & TX  Power/enable pin  4 mounting holes  Reset button  The Feather 328P has some extra space left over, so we give you a tiny little prototyping area. If you  just need to attach a button or sensor, you may be able to skip out on a breadboard and wire it directly  on there.   Comes fully assembled and tested, with a USB bootloader that lets you quickly use it with the Arduino  IDE. We also toss in some header so you can solder it in and plug into a solderless breadboard. Lipoly  battery and USB cable not included (but we do have lots of options in the shop if you'd like!)  Technical Details  Product Dimensions: 50.0mm x 22.8mm x 7.2mm / 2.0" x 0.9" x 0.3"   Product Weight: 4.6g / 0.2oz        https://www.adafruit.com/product/3458 1‐31‐18
很抱歉,暂时无法提供与“3458”相匹配的价格&库存,您可以联系我们找货
