Espruino WiFi
PRODUCT ID: 3514
Description
Try the JavaScript of things with the Espruino WiFi - the world's first open-source JavaScript
microcontroller, this time with built in WiFi! This little board has an STM32 microcontroller preprogrammed with Espruino all ready to go so you can start playing with Javascript-microcontrollers. It also
comes with an ESP8266 WiFi module, so you can connect to the Internet using Espruino. Warning: if you
only use Assembly and think that even embedded C/C++ is for wimps, this device might explode your
head.
The Espruino is a tiny computer with a JavaScript interpreter, allowing for instant feedback from whatever
device you're working with. Simply set up your code with the Espruino and send it to the device without
having to wait for the board to 'flash. With the new Espruino WiFi you get the best of Javascript with
Internet connectivity.
Once you've uploaded code, you can inspect and change variables (including functions!) while your
program is running. There's loads of documentation, tutorials and support for a huge range of different
hardware too. See how to get started here, or if you have any questions ask away on the Espruino forums!
http://www.espruino.com/Reference http://www.espruino.com/Tutorials
http://www.espruino.com/Quick+Start http://forum.espruino.com/
Features
o
o
o
o
o
o
o
o
o
o
o
o
30mm x 23mm (1.2 x 0.9 inch)
On-board Micro USB connector
2 rows of 11 0.1" pins, with 2 extra 0.1" holes
21 GPIO pins : 8 Analog inputs, 20 PWM, 1 Serial, 3 SPI, 3 I2C
Three on-board LEDs (2x user programmable, 1x WiFi activity) and one button.
STM32F411CEU6 32-bit 100MHz ARM Cortex M4 CPU, 512kb flash, 128kb RAM
ESP8266 WiFi (802.11 b/g/n)
All GPIO is 5 volt tolerant (Arduino compatible)
RTC with external oscillator
On-board 3.3v 250mA voltage regulator, accepts voltages from 3.5v to 5v
Current draw in sleep: < 0.05mA - over 2.5 years on a 2500mAh battery
500mA polyfuse on board
The Espruino's fast response time has a lot of advantages. It allows for quick and easy debugging and is a
great way to test your project before your big reveal. In addition, you can control the Espruino from almost
anything - Windows, Mac OS, Linux, RasPi, Android, anything that can talk to a USB Serial port.
The Espruino also interacts well with our NeoPixels. For more info, check out Espruino's page on the
WS2811 and WS2812. http://www.espruino.com/WS2811
While the main advantage of the Espruino is its instant execution, it can also be used as a traditional board
through a Web-based IDE hosted on your computer. The microcontroller also uses less power than Linux
Boards (although its of course a lot less powerful as well) so will run longer on battery power, it has loads
of IO pins, and it can be used as an IO board for PCs, Macs, or Rasp Pis without having to program it first.
Simply take the Espruino out of its packaging and get started!
There's also more info on the Espruino page including tutorials and code examples. There aren't currently
many tutorials using this board, however it can be used just like the Espruino Pico, which has a lot of
tutorials available.
Technical Details
o
o
o
o
o
o
o
Dimensions: 30mm x 23mm x 7.1mm / 1.2" x 0.91" x 0.28"
Weight: 5.6g
Height w/ headers: 13mm / 0.51"
Circuit Diagram
Board Layout
STM32F411CE Datasheet
STM32F411CE Reference Manual
For product support, replacement parts and warranty for Espruino products click here.
http://www.espruino.com/Contact+Us
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3514 5‐18‐17
很抱歉,暂时无法提供与“3514”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+384.149401+49.86884
