Adafruit HTU21D-F Temperature & Humidity
Sensor Breakout Board - Fully Assembled
PRODUCT ID: 3515
https://www.adafruit.com/product/3515#Slide4
DESCRIPTION
It's summer and you're sweating and your hair's all frizzy and all you really want to know is why the
weatherman said this morning that today's relative humidity would max out at a perfectly
reasonable 52% when it feels more like 77%. Enter the HTU21D-F Temperature + Humidity Sensor the best way to prove the weatherman wrong!
This I2C digital humidity sensor is an accurate and intelligent alternative to the much
simpler Humidity and Temperature Sensor - SHT15 Breakout It has a typical accuracy of ±2% with
an operating range that's optimized from 5% to 95% RH. Operation outside this range is still
possible - just the accuracy might drop a bit. The temperature output has an accuracy of ±1°C
from -30~90°C. If you're looking to measure temperature more accurately, we recommend
the MCP9808 High Accuracy I2C Temperature Sensor Breakout Board.
Such a lovely chip - so we spun up a breakout board that includes the Filtered version (the white
bit of plastic which is a PTFE filter to keep the sensor clean), a 3.3V regulator and I2C level shifting
circuitry. This lets you use it safely with any kind of microcontroller with 3.3V -5V power or
logic. Each order comes with one fully assembled and tested PCB breakout with headers attached
and everything.
It's also very easy to use, thanks to our Arduino library and tutorial. Check out our tutorial for
pinouts, wiring, files, etc
TECHNICAL DETAILS
Dimensions (including header): 18mm x 16mm x 11.5mm / 0.7" x 0.6" x 0.4"
Weight: 1.4g
I2C 7-bit address 0x40
PCB CAD files, datasheets, Fritzing object, etc available in the tutorial
很抱歉,暂时无法提供与“3515”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+165.083811+21.38413
