3535
3535
    ADAFRUIT
    VGA TO HDMI AUDIO AND VIDEO ADAP
3535 数据手册
VGA to HDMI Audio and Video Adapter PRODUCT ID: 3535 Description Do you have an an older VGA-output computer, game system, or other device, that you want to hook up to your fancy new HDMI monitor? This converter will take a VGA signal and convert it to every-day HDMI so it will work with your computer monitor, display, television, projector, etc. This high-definition video converter will convert analog stereo audio signal and analog RGBHV from the DB-15 plug and combine them together into digital HDMI signal. Features: o o o o VGA input supports up to 1920x1080P @ 60Hz Separate audio input comes in from line-level 3.5mm audio jack No need to install drivers! The adapter is portable, flexible, plug and play Package includes: VGA->HDMI Converter, USB Power Cable, 3.5mm Male/Male Stereo Cable and User Manual Note: does not come with a USB wall adapter or VGA cable but we do stock them in the shop! Technical Details o o o o o Adapter body dimensions: 63mm x 56mm x 20mm Adapter body weight: 39.5g USB cable length: 30.5" / 775mm 3.5mm cable length: 24.5" / 622mm Powered via mini USB cable, plug into any USB hub, computer, or USB wall adapter (not included)        Engineered in NYC Adafruit ® https://www.adafruit.com/product/3535 6‐23‐17
很抱歉,暂时无法提供与“3535”相匹配的价格&库存,您可以联系我们找货
    库存:6
    3535
      库存:1000
      3535
      • 1+131.832551+17.13502
