Insulated Silicone Rework Mat - 34cm x
23cm x 4mm Work Surface
PRODUCT ID: 3536
Description
This silicone mat is made of 4mm thick rubber and can take just about anything you throw at it. It's stable, strong,
non-slip, non-conductive and heat-resistant surface for your workstation. We love it here at Adafruit because you
can hot air boards right on top and there won't be any damage to our underlying worktable.
It's also skid resistant! The silicone is just soft enough with some grip that it doesn't slide around, and PCBs will stay
in place. The heat insulation increases soldering efficiency and keeps whatever you're working on safely in one
spot. You can use hot air, soldering irons, etc without damage to either the mat or iron. It's anti-stick and resistant to
corrosion, glues and other adhesives, and it can be cleaned with some hot soap and water.
This mat is 34 cm wide, 23 cm tall and 4mm thick molded silicone and equipped with grooves for placing solder
paste, screws, headers, and pretty much any other small accessories. Your order comes with one mat. Solder,
soldering iron, and other components not included.
Technical Details
Product Dimensions: 340.0mm x 230.0mm x 4.0mm / 13.4" x 9.1" x 0.2"
Product Weight: 246.0g / 8.7oz
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3536 6-23-17
很抱歉,暂时无法提供与“3536”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.618071+11.87716
