3537
3537
    ADAFRUIT
    HDMI TO RCA AUDIO AND CVBS NTSC,
3537 数据手册
HDMI to RCA Audio and CVBS NTSC, PAL, or S-Video Converter PRODUCT ID: 3537        Description Do you have a S-Video display, projector or monitor that is not compatible with your HDMI devices? Here's an adapter that will allow you to convert HDMI to S-Video, for older video devices that might not have an HDMI input. S-Video has better performance than plain "RCA" composite NTSC/PAL as it separates the color and light level, so if you have a device that can take either S-Video or NTSC/PAL composite, you're better off going with S-Video! Note that you still won't get something as nice as HDMI, as analog is just noisier than high-definition digital. This mini HDMI to S-Video signal converter box will convert HDMI video+audio signal to either Composite Video or S-Video - selectable by a switch on the side. You can do either NTSC or PAL encoding, also with a switch. Ta-da! Your HDMI-output-only device can now hook up to your analog TV. Features: o o o o o o o o o Compatible with HDMI 1.3 Not compatible with 3D or HDCP, so turn those off! Input HDMI resolution: 480p (60Hz), 576p (50Hz), 720p (50Hz / 60Hz), 1080i (50Hz / 60Hz), 1080p (50Hz / 60Hz) Output signal: Stereo line level audio Left and Right as well as Composite Video or S-Video Output video systems: PAL or NTSC Output video impedance: 75Ω Power supply: DC 5V 2.1mm Working temperature: -25°C ~ 75°C Working humidity: 10%–60% Package includes: Converter, 5V Power Supply, 3-channel AV Cable, S-Video Cable and User Manual Note: This product does not support simultaneous output of Composite Video and S-Video. Please select either one of them using the switch on the unit itself.  Technical Details o o o o o Adapter body dimensions: 110mm x 85mm x 30mm Adapter body weight: 194g AV cable length: 1.5m S-Video cable length: 1.5m Power supply length (wire only): ~42"                                                    Engineered in NYC Adafruit ® https://www.adafruit.com/product/3537 6‐23‐17
很抱歉,暂时无法提供与“3537”相匹配的价格&库存,您可以联系我们找货
