3539
3539
    ADAFRUIT
    HYDRO DIPPING SHEETS 10PK A4
3539 数据手册
      Hydro Dipping Sheets – 10 Pack of A4 Size Sheets PRODUCT ID: 3539       Description Hydro dipping is a fun, hands‐on way of adding printed designs to any surface! This process can  be done on any material that can hold the base coat and can be submerged into water. Works really  well with any 3D printed project, but molded and cast parts also benefit. You've probably seen cool  videos of motorcycle helmets and ceramic statues being dipped ‐ when done right you can cover an  entire shape with colorful ink.  Start by using an ink‐jet printer (laser printers wont work!) and print on your design. Solid, abstract and  repeating patterns work best because it can be challenging to line up the artwork when you're doing  the dip. After printing a pattern or design, the thermal paper is floated on top of a vat of hot water.  The ink will float, held together by a thin clear polymer layer on the top. Prepare and slowly dip your  piece at a 45 degree angle into the water, the image is transferred onto your project. If it doesn't quite  turn out, you can scrub it off before the ink sets.  Note it does take a little practice to get good at this technique, but we have a handy DIY video that  takes you through the process with lots of tips!  This thermal paper is A4 size and works best with water‐based pigment ink. Comes in a pack of 10  sheets you can cut the sheets down and/or reuse un‐printed parts as long as you have enough border  space.    Technical Details Product Dimensions: 300.0mm x 210.0mm x 0.2mm / 11.8" x 8.3" x 0.0"   Product Weight: 8.0g / 0.3oz        https://www.adafruit.com/product/3539 9‐8‐17
很抱歉,暂时无法提供与“3539”相匹配的价格&库存,您可以联系我们找货
    库存:1000
    3539
    • 1+111.087271+14.37211
