3544
3544
    ADAFRUIT
    MINIATURE DESKTOP FAN - 12V
3544 数据手册
    Miniature Desktop Fan - 12V PRODUCT ID: 3544       Description This little desktop fan is simple but super handy. It's a ~12VDC fan in a nice enclosure, you can sit it on  your desk and power it off of any 9V or 12VDC power supply (even a USB booster cable if you want).  We've used this fan pointing out to cool off hot projects or PCBs after reworking, or turn it around to  make it an exhaust fan during soldering.  It has a magnet in its base, making it easy to be fixed upon an iron or metal surface (maybe a good  match for the Mag Hand workstation?). It's nice and quiet while operating and will fit in quite nicely  with any workstation. There's an on/off switch when you're done working. It's hard not to be a fan of  this fan!  Power supply is not included ‐ technically it is rated for 12VDC but we've used it at 9VDC just fine. You  can pick up a 9V 1A power supply here or if you have USB outlets, try a 12V USB booster cable.  Technical Details o o Power in via 5.5/2.1mm center‐positive DC jack  Draws 0.2A at 12VDC rated operation  Product Dimensions: 145.0mm x 116.0mm x 43.0mm / 5.7" x 4.6" x 1.7"   Product Weight: 222.0g / 7.8oz        https://www.adafruit.com/product/3544 8‐8‐17
很抱歉,暂时无法提供与“3544”相匹配的价格&库存,您可以联系我们找货
