3562
3562
    ADAFRUIT
    位置 带状 Cable 11.8"(300.0mm)
3562 数据手册
      DIY HDMI Cable Parts - 30 cm HDMI Ribbon Cable PRODUCT ID: 3562         Description If you're looking to make a custom cable with any two of our HDMI adapters, then you'll need to have  these flex cables handy! Making custom HDMI cables has never been easier. Just grab one of these  cables, then swap and switch any of the HDMI adapters on each end using the flex cable clips.  There are options a‐plenty!  This is the 30 cm (~12 inches) version.  The two required HDMI adapters are not included! Check out all of the options we have in the shop to  craft your very own custom cable.  We tested out these DIY cable kits with a Raspberry Pi at 1080P and they worked great but note that  they are not going to be as durable or shielded as ready‐made cables.    Technical Details o o o Cable Length: 300mm  Cable Width: 10mm / 0.4"  Weight: 1.5g                                   https://www.adafruit.com/product/3562 9‐6‐17
很抱歉,暂时无法提供与“3562”相匹配的价格&库存,您可以联系我们找货
