Adafruit Touch Screen Breakout Board for
4 pin 1.0mm FPC
PRODUCT ID: 3575
Description
If you've got a resistive touch screen that you'd like to use, you'll need this breakout! It has a medium
pitch (1.0mm) connector soldered onto it, and it's broken out into the four resistive wires of the panel.
If you need a breakout for 0.5mm‐pitch touch panels, check out this product. If you want a breakout
with a resistive‐panel control driver chip on it, our STMPE I2C/SPI breakout or USB AR1100 driver will
do what you need!
This is a petite 0.5"x0.5" (12.7mm x 12.7mm) breakout board with two mounting holes as well that you
can use for strain relief. Works perfectly with our 7" touch screen and any other touch screen with
1.0mm pitch. The connector we use is double‐sided so you can use it with top‐contact or bottom‐
contact flex PCBs.
Check out our great example Arduino library code that shows how to get readings, debounce, and read
the pressure from any touch screen (so you can detect when it's being touched and how hard). The
code is not complex and is easily ported to other microcontrollers.
Technical Details
Product Dimensions: 12.7mm x 12.7mm x 4.5mm / 0.5" x 0.5" x 0.2"
Product Weight: 0.5g / 0.0oz
https://www.adafruit.com/product/3575 8‐15‐17
很抱歉,暂时无法提供与“3575”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+23.742861+2.97740
