3611
3611
    ADAFRUIT
    ADAFRUIT STEMMA - TSL2561 DIGITA
3611 数据手册
STEMMA - TSL2561 Digital Lux / Light Sensor PRODUCT ID: 3611    Description New from Adafruit, we are taking our most popular sensors and making them easier than ever to use!  This is the Adafruit STEMMA TSL2561 which takes our favorite lux sensor and gives you two ways to  play: you can use alligator clips to connect the sensor to your Flora, Gemma or Circuit Playground, or  plug‐n‐play with STEMMA cables or Seeed Grove cables  Each STEMMA board has level‐shifting and protection circuitry on the power supply and data lines so  you can design with no worries about incompatibilities or accidents.  The TSL2561 luminosity sensor is an advanced digital light sensor, ideal for use in a wide range of light  situations. Compared to low cost CdS cells, this sensor is more precise, allowing for exact lux  calculations and can be configured for different gain/timing ranges to detect light ranges from up to 0.1  ‐ 40,000+ Lux on the fly. The best part of this sensor is that it contains both infrared and full spectrum  diodes! That means you can separately measure infrared, full‐spectrum or human‐visible light. Most  sensors can only detect one or the other, which does not accurately represent what human eyes see  (since we cannot perceive the IR light that is detected by most photo diodes)  The sensor has a digital (i2c) interface. You can select one of three addresses so you can have up to  three sensors on one board ‐ each with a different i2c address. The built in ADC means you can use this  with any microcontroller, even if it doesn't have analog inputs. The current draw is extremely low, so  its great for low power data‐logging systems. about 0.5mA when actively sensing, and less than 15 uA  when in powerdown mode.    Of course, we wouldn't leave you with a datasheet and a "good luck!" ‐ we wrote a detailed tutorial  showing how to use it with an Arduino and example code that gets readings and calculates lux   https://cdn‐learn.adafruit.com/downloads/pdf/tsl2561.pdf   Technical Details o o o o o o o Approximates Human eye Response   Precisely Measures Illuminance in Diverse Lighting Conditions   Temperature range: ‐30 to 80 *C  Dynamic range (Lux): 0.1 to 40,000 Lux  Voltage range: 2.7‐3.6V  Interface: I2C  This board/chip uses I2C 7‐bit addresses 0x39 (default), 0x29, 0x49, selectable with  jumpers  We have a detailed tutorial showing how to use it with an Arduino and example code that gets readings  and calculates Lux  https://cdn‐learn.adafruit.com/downloads/pdf/tsl2561.pdf  Product Dimensions: 25.8mm x 25.8mm x 7.3mm / 1.0" x 1.0" x 0.3"   Product Weight: 2.0g / 0.1oz        https://www.adafruit.com/product/3611 9‐15‐17
很抱歉,暂时无法提供与“3611”相匹配的价格&库存,您可以联系我们找货
  • 1+75.935101+9.85499
