3622
3622
    ADAFRUIT
    AMG8833 温度(IR) 传感器 羽毛 平台评估扩展板
3622 数据手册
    Adafruit AMG8833 IR Thermal Camera FeatherWing PRODUCT ID: 3622   Description A Feather board without ambition is a Feather board without FeatherWings! This is the Thermal  Camera FeatherWing: thanks to the Panasonic AMG8833 8x8 GridEYE sensor, it adds heat‐vision to any  Feather main board. Using our Feather Stacking Headers or Feather Female Headers you can connect a  FeatherWing on top of your Feather board and let the board take flight!  This sensor from Panasonic is an 8x8 array of IR thermal sensors. When connected to your Feather it  will return an array of 64 individual infrared temperature readings over I2C. It's like those fancy  thermal cameras, but compact and simple enough for easy integration.  This part will measure temperatures ranging from 0°C to 80°C (32°F to 176°F) with an accuracy of +‐  2.5°C (4.5°F). It can detect a human from a distance of up to 7 meters (23) feet. With a maximum frame  rate of 10Hz, It's perfect for creating your own human detector or mini thermal camera. We have an  easy‐to use Arduino and CircuitPython code so you can get started fast. The sensor communicates over  I2C. If you have a fast Feather like the ESP8266, ESP32 or Teensy, you can interpolate the 8x8 grid and  get some pretty nice results! (The video above shows a peace‐sign finger  demo using a Teensy Feather  and 24x24 interpolation)  The AMG8833 is the next generation of 8x8 thermal IR sensors from Panasonic, and offers higher  performance than it's predecessor the AMG8831. The sensor only supports I2C, and has a configurable  interrupt pin that can fire when any individual pixel goes above or below a threshold that you set.  Pair this up with our TFT FeatherWing and some stackin' headers to make the snazzy Thermal Camera  demo shown above ‐ Feather and TFT Wing not included.    Technical Details Check our our detailed guide for wiring diagrams, datasheets, schematics, libraries, code, Fritzing  objects, etc!   https://cdn‐learn.adafruit.com/downloads/pdf/adafruit‐amg8833‐8x8‐thermal‐camera‐sensor.pdf  Product Dimensions: 50.0mm x 23.0mm x 6.1mm / 2.0" x 0.9" x 0.2"   Product Weight: 4.7g / 0.2oz        https://www.adafruit.com/product/3622 10‐10‐17
很抱歉,暂时无法提供与“3622”相匹配的价格&库存,您可以联系我们找货
