3624
3624
    ADAFRUIT
    万用表 LCD - 白色字符,背光 显示 面板安装
3624 数据手册
    Mini Power Meter with Voltage, Current, Watts, mAh & mWh Display PRODUCT ID: 3624         Description This Mini Power Meter with Voltage, Current, Watts, mAh & mWh Display (whew that is a mouth‐full) is  a lot like the USB In‐Line Voltage and Current Meter we carry but can  be used with a wide range of  voltages (not just USB connections). Measure the working voltage and current output for any project  with this really fancy power meter.  This power meter has a small LCD display that shows off voltage, watts, amps, and mAH and instantly  reads the numbers out for testing devices, such as chargers, cables, and cell phones. There are a few  nice extras in this very fancy monitor, such as showing the impedance of the connected device as well  as calculating the cumulative Watt‐hours and milliAmp‐hours over a running time. Basically it's an all‐ in‐one power management solution that doesn't require any calculation or data logging on your part.  You can have it self‐power from the power source it's measuring (it has a quiescent of about 20mA and  requires at least 3V), or you can power separately from a JST connector or power‐only micro USB  socket.  Comes with  o o o 1 x 2‐pin JST Connector   2 x Positive Alligator Test Clips  2 x Negative Alligator Test Clips  Technical Details Dimensions: 48mm x 29mm x 21mm / 1.8" x 1.1" x .8"  Weight: 15g  Voltage measuring range: 1.00 V ‐ 100.00 V (when powered separately)  Voltage measuring range: 3.00 ‐ 40.00V (when powered by device  Voltage resolution & precision:  0.0001V / 0.01V   Current measuring range: 0.0000 to 15.00 A  Current resolution & precision: 0.0001 A / 0.01A  Cumulative capacity range: 0 to 99999 mAh  Cumulative resolution/precision: 0.001 Ah  Power cumulative range: 0 to 999999 MWh  Power cumulative resolution/precision: 0.001 Wh  Power metering range: 0 to 299.999 W  Power meter resolution precision: 0.001 W  Impedance measurement range: 1 ‐ 999.99 ohms  Impedance resolution/precision: 0.01 ohms  Temperature measurement range: 0 ~ 80Ԩ  Temperature resolution/precision: 1 degree  Timing maximum time: 999h 59min 59s  Timing resolution/precision: 1 second  Measurement rate: 2 Hz  Display type: LCD module with white graphical display  Quiescent current draw:
很抱歉,暂时无法提供与“3624”相匹配的价格&库存,您可以联系我们找货
