3628
3628
    ADAFRUIT
    适配器连接器 USB-A(USB TYPE-A),插头 至 接线板,接头,5 位置,1 排
3628 数据手册
    USB-A Male Plug to 5-pin Terminal Block PRODUCT ID: 3628   Description This is the USB‐A Male Plug to 5‐pin Terminal Block. If you need to connect to a device with a USB Jack,  maybe make your own USB stick or custom cable of sorts ‐ this adapter will come in very handy! No  soldering required. Just use a small screwdriver to open up the terminal blocks, slide in your stranded  or solid‐core wire, and re‐tighten.  The terminal block itself is removable from the body. It's more durable than soldering wires onto a  connector and all the pins are labeled, which is really nice because we keep forgetting the order. The  5th pin is for the Sleeve of the connector.  Technical Details  Terminal Block Pitch: 5mm  Product Dimensions: 52.0mm x 19.0mm x 11.4mm / 2.0" x 0.7" x 0.4"   Product Weight: 12.1g / 0.4oz        https://www.adafruit.com/product/3628 11‐28‐17
很抱歉,暂时无法提供与“3628”相匹配的价格&库存,您可以联系我们找货
  • 1+43.396301+5.59050
库存:21
