Large Panel-Mount Digital Power Meter 6.5V to 100VDC up to 20A
PRODUCT ID: 3626
DESCRIPTION
What do you do when you need a variety of measurements on your current
project? (pun intended!) You could buy a slew of test equipment tools OR you
could use this very nice panel-mount multi-function power meter! This power
meter comes with a nice, big (and backlit!) LCD screen to display voltage,
current, power, and energy parameters.
You can use this meter to find out if your voltage is too low or your current draw
is too high. It even does some nice calculations for you like Watts and
cumulative Watt-hours. There is a small recessed button you can use to reset
the cumulative measurements.
It is powered by the load it measures so wiring is very simple - two wires in, two
wires out. Great for bench-top use or for embedding into your project's
enclosure (note that it is meant for indoor use only.) Unlike some of our other
power meters, this one requires 6.5VDC, and you cannot power it externally so
it's good for higher-voltage projects not for microcontrollers.
TECHNICAL DETAILS
Product Dimensions: 90.0mm x 50.0mm x 24.0mm / 3.5" x 2.0" x 0.9"
Product Weight: 61.6g / 2.2oz
https://www.adafruit.com/product/3626 11‐11‐17
很抱歉,暂时无法提供与“3626”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+157.647261+20.38808
