3631
3631
    ADAFRUIT
    可寻址照明 Neopixel 20 LED 带 红色,绿色,蓝色,白色(RGBW)
3631 数据手册
          Adafruit NeoPixel LED Strand 20 LED 4" Pitch PRODUCT ID: 3631   Description Attaching NeoPixel strips to your costume can be a struggle as the flexible PCBs can crack when bent  too much. So how to add little dots of color? Use these stranded NeoPixel dots! They're very small, so  they're easy to embed into any structure, costume, or wearable. Each dot is enclosed in a small plastic  weatherproof button, we don't recommend dunking these underwater but they can survive temporary  outdoor usage. Best of all the buttons have little plastic hooks molded into the back so they can be  tack‐sewn in place.  Each strand has 20 dots with a single NeoPixel inside with cabling connecting them. The dots are 4"  apart, we also have a version that is 2" apart.  NeoPixels are 5050‐sized LEDs with an embedded microcontroller inside the LED. You can set the  brightness of each R/G/B/W. Each LED acts like a shift register, reading incoming data on the input pins,  and then shifting the previous data out on the output pin. By sending a long string of data, you can  control an infinite number of LEDs, just tack on more or disconnect unwanted LEDs at the end. The  PWM is built into each LED‐chip so once you set the brightness you can stop talking to the strip and it  will continue to PWM all the LEDs for you.  These NeoPixel strands have 20 digitally‐addressable pixel LEDs per meter. We have a tutorial showing  wiring, power usage calculations, example code for usage, etc. Please check it out!  https://cdn-learn.adafruit.com/downloads/pdf/adafruit-dotstar-leds.pdf      Technical Details        https://www.adafruit.com/product/3631 12‐8‐17
很抱歉,暂时无法提供与“3631”相匹配的价格&库存,您可以联系我们找货
    • 1+222.44760
    • 200+88.76520
    • 500+85.79520
    • 1000+84.32640
