Adafruit NeoPixel LED Side Light Strip ‐ Black
120 LED
PRODUCT ID: 3634
Description
Fancy new side light LED strips are a great alternative for folks who have loved and used Adafruit LED
strips for a few years but want gorgeous, glowy light emitting at 90 degrees. They're very skinny so you
can run them along a thin edge and curve them around shapes and corners. These look awesome for
accent lighting, back lighting, edge lighting, etc!
This is the 120 LED‐per‐meter version of our Side Light strips. We also have 60 LED/m and 90 LED/m on
black flex PCB.
The strip is constructed of flexible black PCB material with weatherproof sheathing. You can cut this
stuff pretty easily with wire cutters. There is a cut line halfway down the strip. Solder to the 0.1"
copper pads, and you're good to go! Of course, you can also connect strips together to make them
longer, just watch how much current you need!
These strips come in 1‐meter reels with a 2‐pin JST SM connector on each end. To wire up these strips
we suggest picking up some JST SM plug and receptacle cables for the signal wires. For the power
wires, you will also probably want a 2.1mm DC jack to wire in, so you can connect one of our 5V wall
adapters to power it.
We have a tutorial showing wiring, power usage calculations, example code for usage, etc. Please check
it out!
https://cdn‐learn.adafruit.com/downloads/pdf/adafruit‐neopixel‐uberguide.pdf
Technical Details
o
o
o
o
Storage temperature: ‐40~ +80°C
Operating temperature: ‐25~ +60°C
Strip width: 10mm
LED pitch: 8mm
https://www.adafruit.com/product/3631 12‐8‐17
很抱歉,暂时无法提供与“3634”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+285.84360
- 200+114.05880
- 500+110.24640
- 1000+108.35640
