3635
3635
    ADAFRUIT
    可寻址照明 - 90 LED 灯条(黑色) 1000.00mm 长
3635 数据手册
        Adafruit NeoPixel LED Side Light Strip ‐ Black 90 LED PRODUCT ID: 3635   Description Fancy new side light LED strips are a great alternative for folks who have loved and used Adafruit LED  strips for a few years but want gorgeous, glowy light emitting at 90 degrees. They're very skinny so you  can run them along a thin edge and curve them around shapes and corners. These look awesome for  accent lighting, back lighting, edge lighting, etc!   This is the 90 LED‐per‐meter version of our Side Light strips. We also have 60 LED/m and 120 LED/m on  black flex PCB.  The strip is constructed of flexible black PCB material with weatherproof sheathing. You can cut this  stuff pretty easily with wire cutters. There is a cut line halfway down the strip. Solder to the 0.1"  copper pads, and you're good to go! Of course, you can also connect strips together to make them  longer, just watch how much current you need!   These strips come in 1‐meter reels with a 2‐pin JST SM connector on each end. To wire up these strips  we suggest picking up some JST SM plug and receptacle cables for the signal wires. For the power  wires, you will also probably want a 2.1mm DC jack to wire in, so you can connect one of our 5V wall  adapters to power it.  We have a tutorial showing wiring, power usage calculations, example code for usage, etc. Please check  it out!  https://cdn‐learn.adafruit.com/downloads/pdf/adafruit‐neopixel‐uberguide.pdf      Technical Details  o o o o Storage temperature: ‐40~ +80°C  Operating temperature: ‐25~ +60°C  Strip width: 8mm  LED pitch: 11mm        https://www.adafruit.com/product/3635 12‐8‐17
很抱歉,暂时无法提供与“3635”相匹配的价格&库存,您可以联系我们找货
  • 1+237.057941+30.81176
库存:1
