Adafruit PT1000 RTD Temperature
Sensor Amplifier - MAX31865
PRODUCT ID: 3648
Description
For precision temperature sensing, nothing beats a Platinum RTD. Resistance temperature detectors
(RTDs) are temperature sensors that contain a resistor that changes resistance value as its temperature
changes, basically a kind of thermistor. In this sensor, the resistor is actually a small strip of Platinum
with a resistance of 1000 ohms at 0°C, thus the name PT1000. Compared to most NTC/PTC thermistors,
the PT type of RTD is much most stable and precise (but also more expensive) PT1000's have been used
for many years to measure temperature in laboratory and industrial processes, and have developed a
reputation for accuracy (better than thermocouples), repeatability, and stability.
However, to get that precision and accuracy out of your PT1000 RTD you must use an amplifier that is
designed to read the low resistance. Better yet, have an amplifier that can automatically adjust and
compensate for the resistance of the connecting wires. If you're looking for a great RTD sensor, today is
your lucky day because we have a lovely Adafruit RTD Sensor Amplifier with the MAX31865 breakout
for use with any 2, 3 or 4 wire PT1000 RTD!
If you have a PT100 RTD, please visit this page to purchase a version of this board with the reference
resistor for 100‐ohm RTDs
We've carried various MAXIM thermocouple amplifiers and they're great ‐ but thermocouples don't
have the best accuracy or precision, for when the readings must be as good as can be. The MAX31865
handles all of your RTD needs, and can even compensate 3 or 4 wire RTDs for better accuracy. Connect
to it with any microcontroller over SPI and read out the resistance ratio from the internal ADC. We put
a 4300Ω 0.1% resistor as a reference resistor on the breakout. We have some example code that will
calculate the temperature based on the resistance for you.
We even made the breakout 5V compliant, with a 3.3V regulator and level shifting, so you can use it
with any Arduino or microcontroller.
Each order comes with one assembled RTD amplifier breakout board. Also comes with two 2‐pin
terminal blocks (for connecting to the RTD sensor) and pin header (to plug into any breadboard or
perfboard). A required PT1000 RTD is not included! (But we stock them in the shop). Some soldering is
required to solder the headers and terminal blocks to the breakout, but it's an easy task with soldering
tools.
Please note: this does not include an RTD sensor! Also, the terminal blocks included with your product
may be blue or black
Technical Details
Product Dimensions: 28.0mm x 25.0mm x 2.4mm / 1.1" x 1.0" x 0.1"
Product Weight: 2.6g / 0.1oz
https://www.adafruit.com/product/3242 10‐30‐17
很抱歉,暂时无法提供与“3648”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+278.69400
- 200+111.20760
- 国内价格 香港价格
- 1+142.597541+18.48336
