3649
3649
    ADAFRUIT
    可寻址照明 - 4096(64 x 64) LED 矩阵 串行 红色,绿色,蓝色(RGB) 160.00mm 长 x 160.00mm 宽
3649 数据手册
64x64 RGB LED Matrix - 2.5mm Pitch - 1/32 Scan PRODUCT ID: 3649 Description • Winter time can be rough in the city. The sky is gray. The weather is unpredictable. So slough off those seasonal blues with some Times Square razzle dazzle from this sweet, ultra-high-density 64x64 RGB LED Matrix. These panels are typically used to make video walls. Here in New York we see them on the sides of buses and on top of taxi cabs displaying animations or video advertisements. We thought they looked really cool, so we picked up a few boxes of them from a factory. They have 4,096 bright RGB LEDs arranged in a 64x64 grid at a 2.5mm pitch. WARNING! These 64-pixel tall matrices use a non-standard 5-address multiplexing system! WARNING! Many add-ons or drivers use only a 4-address (ABCD) setup. Right now the only board we have that can use these big matricies is our RGB Matrix Bonnet for Raspberry Pi, and you'll need to connect a solder jumper. Other libraries such as our Arduino library, or our HDMI driver boards don't support 5-address multiplexing! • Full Kit Contents: o o o o 64x64 RGB panel IDC ribbon cable (~200mm) power cable (~480mm) 4 mounting screws and mini-magnets Technical Details o o o o o o o o Brightness: 2800cd/square meter Size: 160x160mm Pitch: 2.5M 5 Addressable Pins Scan: 1/32 Refresh Frequency: >=400HZ Waterproof Class: IP43 Weight: 204.8g (only matrix panel). 255g (w/ components) Best for indoor use Product Dimensions: 160.0mm x 160.0mm x 17.6mm / 6.3" x 6.3" x 0.7" Product Weight: 204.8g / 7.2oz
很抱歉,暂时无法提供与“3649”相匹配的价格&库存,您可以联系我们找货
