3650
3650
    ADAFRUIT
    INA219 电流,电源监控器 传感器 羽毛 平台评估扩展板
3650 数据手册
      Adafruit INA219 FeatherWing PRODUCT ID: 3650           Description The INA219 FeatherWing makes power‐monitoring problems a thing of the past. Instead of struggling  with two multimeters, you can just use the handy INA219B chip on this breakout to both measure both  the high side voltage and DC current draw over I2C with 1% precision. Works with any and all Feathers!  Communicates over I2C so its super‐simple to use, you can even change the I2C address to have up to 4  of these Wings on one Feather.    Many current‐measuring devices are only good for low side measuring. That means that unless you  want to get a battery involved, you have to stick the measurement resistor between the target ground  and true ground. This can cause problems with circuits since electronics tend to not like it when the  ground references change and move with varying current draw. This chip is much smarter ‐ it can  handle high side current measuring, up to +26VDC, even though it is powered with 3.3V. It will also  report back that high side voltage, which is great for tracking battery life or solar panels.    A precision amplifier measures the voltage across the 0.1 ohm, 1% sense resistor. Since the amplifier  maximum input difference is ±320mV this means it can measure up to ±3.2 Amps. With the internal 12  bit ADC, the resolution at ±3.2A range is 0.8mA. With the internal gain set at the minimum of div‐8, the  max current is ±400mA and the resolution is 0.1mA. Advanced hackers can remove the 0.1 ohm current  sense resistor and replace it with their own to change the range (say a 0.01 ohm to measure up 32  Amps with a resolution of 8mA)    Technical Details Product Dimensions: 51.0mm x 22.8mm x 3.6mm / 2.0" x 0.9" x 0.1"   Product Weight: 3.4g / 0.1oz        https://www.adafruit.com/product/3650 10‐30‐17
很抱歉,暂时无法提供与“3650”相匹配的价格&库存,您可以联系我们找货
