3661
3661
    ADAFRUIT
    AP3602A - DC/DC,步升 1,非隔离 输出评估板
3661 数据手册
      Adafruit MiniBoost 5V @ 100mA Charge Pump - AP3602A PRODUCT ID: 3661         Description This adorable little board will come in very handy whenever you need a small amount of 5V power. It's  the size of a linear regulator, but it's actually a mini‐booster! Input 3V on one side, and get 5V at up to  100mA supply on the other. Perfect for use with battery‐powered projects with 2 or 3 Alkaline, or a  single Lithium battery. For big projects, you may want one of our PowerBoost boards that can give you  a honkin' 500mA‐2A of current.  This booster uses a charge‐pump topology, which makes it very compact and low cost. But it isn't as  efficient as a inductor‐based boost converter. Charge‐pumps always double the incoming voltage, and  then regulate down. So yeah, not as efficient. So ideal for when you aren't counting coulombs ‐ or  when your current draw isn't terribly high.  You get one fully assembled breakout with an AP3602A and components, and a small bit of header.  Give 3‐5VDC on the IN and ground pins. Then you'll have 5V on the OUT pin. The enable pin can be  pulled low to disable the output.  Technical Details Product Dimensions: 15.0mm x 10.0mm x 3.0mm / 0.6" x 0.4" x 0.1"   Product Weight: 0.6g / 0.0oz        https://www.adafruit.com/product/3661 11‐13‐17
很抱歉,暂时无法提供与“3661”相匹配的价格&库存,您可以联系我们找货
