3679
3679
    ADAFRUIT
    缆线组件 USB A 公插头转 Micro USB B 公头,USB C 公头和 i5 闪电接口 3.28'(1.00m)
3679 数据手册
        USB 3‐in‐1 Sync and Charge Cable ‐ Micro B /  Type‐C / Lightning  PRODUCT ID: 3679  As USB technology evolves you'll want the One Cable To Sync/Charge All Things (or, at least,  portable devices with Micro‐B, Type C, or Lightning ports) and this cable will do the job nicely  This  very  nice USB  3‐in‐1 Charging  Cable looks  like  woven  mithril  forged  from  the  Mines  of  Moria. It's a very handy item to have on a quest because everyone in the Fellowship wants to  charge  their  phones  at  the  Prancing  Pony.  And,  what  to  do  when  everyone's  phone  has  a  different  connector  and,  unsurprisingly,  a  Brandybuck  and  a  fool  of  a  Took  forgot  to  pack  theirs?  Luckily,  you  can  charge  a  wide  variety  of  smartphones  and  devices  with  this  cable,  iPhones, Android, Metro M0 Express, etc!  Unlike  most  cables,  these  are  not  just  charging  cables,  but  also  work  as  data‐sync  cables,  for  iOS, Android and other devices. The clever adapter caps make setup easy, just stack whichever  connector you need!  TECHNICAL DETAILS  Length: 100cm / ~39"   Product Weight: 24.0g / 0.8oz                                                            https://www.adafruit.com/product/3679 1‐26‐18
3679
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款用于红外遥控系统的接收器,具有高灵敏度和低功耗的特点。
3. 引脚分配:EL817共有3个引脚,分别为Vcc、Out和GND。
4. 参数特性:工作电压范围为3-6V,工作电流为1mA,接收频率为38kHz。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号。
6. 应用信息:广泛应用于电视、空调等家用电器的遥控系统中。
7. 封装信息:EL817采用SOP-8封装。
很抱歉,暂时无法提供与“3679”相匹配的价格&库存,您可以联系我们找货
库存:4
