Solder‐free Stackable Banana Plugs 4mm ‐ Pack of
5 Multi Color
PRODUCT ID: 3694
These Banana Plugs not only look great, they're also solder‐free and stackable! Banana plugs are often
used on test equipment, tools, synthesizers and other electronic patch panels. Each connector is
designed with bowed strips to provide secure and uniform contact between the plug and jack. Even
after multiple insertions, the non‐collapsing design stays true to form. The plug springs are nickel‐
plated Beryllium copper and will last for many many years and insertions.
Each plug has a small machine screw, when opened from the top you can stick a solid core or stranded
wire into the side of the plug and then screw it back down. Then you can stack as many as you like to
create complex wiring kits. So they're great for any use.
Comes as a pack of 5, you get one of each lovely color. We also have panel‐mountable Banana Jacks
that go well with these plugs.
Technical Details
o
o
o
o
Cable: 22AWG‐14AWG
Voltage: Up to 30V AC ‐ 60V DC
Current: Up to 15A
Weight (single plug): 4.8g
https://www.adafruit.com/product/3694 1‐23‐18
很抱歉,暂时无法提供与“3694”相匹配的价格&库存,您可以联系我们找货
