Solar Digital Calipers
PRODUCT ID: 3720
Praise the sun! You will never have that awkward situation where your caliper battery dies just when
you need to take a measurement. Sure, if you have the budget, we recommend these near‐
indestructable high‐end Mitutoyo calipers. But these are very fine calipers as well. The jaws are plastic,
so not good for hot metal measurements or when you need perfectly flat jaws.
In particular, these caught our eye since they are solar powered and have a battery backup. Perfect for
sustainable measuring in the hot desert. Or just when you keep coin batteries stocked at all time. If
you're in a lit area (where the lux rating is over 200), the solar panel will power the calipers.
Alternatively, if you're in darker surroundings (like in your secret underground lair and the power just
went out), the 3V battery will take over. One button converts the measurement from millimeters to
inches, and they're perfect for measuring components.
One thing to note is that you will need to zero the calipers when turning them on. It's no big deal ‐ just
close the jaws after turning on, and press the Zero button.
Check out our calipers tutorial here. While these aren't as fancy as the Mitutoyo Digital Calipers, many
of the same instructions apply!
Note: Color of calipers may vary!
Technical Details
Specifications
o
o
o
o
o
o
o
o
Range: 0~150mm / 6"
Accuracy: ±0.2mm / ±0.01"
Resolution: 0.1mm / 0.01"
Repeatability: 0.1mm / 0.01"
Maximum measuring speed: 1.5mm / sec, 60" / sec
Power: When light is over 200 lux, the solar panel will activate. When light is under 200
lux, the 3V battery will supply power.
Operating temperature: 0ºC ~ +40ºC
Storage temperature: ‐20ºC ~ +70ºC
https://www.adafruit.com/product/3720 2‐12‐18
很抱歉,暂时无法提供与“3720”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+127.612901+16.25310
- 国内价格 香港价格
- 1+140.289101+18.18414
