3773
3773
    ADAFRUIT
    KITTENBOT SILICONE SLEEVE
3773 数据手册
      KittenBot Silicone Sleeve for micro:bit Red PRODUCT ID: 3773 This is possibly the cutest, angriest cat face we've ever seen. Even better, the KittenBot Silicone Sleeve protects and accessorizes your micro:bit board! The silicone is super soft yet has enough stretch to snugly fit on your board without fear of tearing, and the white bottom "bumper" slips on very securely when you don't want to plug your micro:bit into our DragonTail breakout. The rubber over the LED matrix is very thin, so the red LEDs will shine through when they're lit. Also, the kitten ears on this charming little case can also turn your micro:bit into a wearable, so you can tote around your adorable, blinky micro:bit. Available in a range of colors! TECHNICAL DETAILS Product Dimensions: 56.0mm x 45.0mm x 12.0mm / 2.2" x 1.8" x 0.5" Product Weight: 11.8g / 0.4oz                                                            https://www.adafruit.com/product/3773 5‐14‐18
很抱歉,暂时无法提供与“3773”相匹配的价格&库存,您可以联系我们找货
