3779
3779
    ADAFRUIT
    AS7262 - 光,彩色传感器 评估板 - 传感器
3779 数据手册
        Adafruit AS7262 6-Channel Visible Light / Color Sensor Breakout PRODUCT ID: 3779 The colors of the rainbow, so pretty in the sky Are also in this sensor, controlled by you and I! Detect trees of green, and red roses too with the new Adafruit AS7262 6Channel Visible Light / Color Sensor Breakout. This sensor from AMS has 6 integrated visible light sensing channels for red, orange, yellow, green, blue, and violet. These channels can be read via the I2C bus as either raw 16-bit values or calibrated floating-point values. There is also an on-board temperature sensor that can be used to read the temperature of the chip, and a powerful LED flash to reflect light off objects for better color detection. The 6 channels on the AS7262 are realized by silicon interference filters at 450nm, 500nm, 550nm, 570nm, 600nm, and 650nm. This breakout uses the I2C interface on the chip by default, but a UART interface that accepts AT commands is also selectable. We've placed the sensor on a PCB for you and included an SPI flash chip preprogrammed with the device firmware, a 3.3V regulator, I2C level shifting, and the recommended LED flash. Both the I2C and UART interfaces are broken out, making this breakout an excellent all-in-one solution for all your color-sensing needs. The pinout for the UART interface is plug-and-play compatible with the Adafruit FTDI Friend. We've also prepared software libraries to get you up and running in Arduino or CircuitPython with just a few lines of code! Check out our full guide for schematics, datasheets, Arduino & CircuitPython code and more! https://cdn-learn.adafruit.com/downloads/pdf/adafruit-as7262-6-channel-visible-light-sensor.pdf Product Dimensions: 27.8mm x 25.0mm x 3.9mm / 1.1" x 1.0" x 0.2" Product Weight: 2.6g / 0.1oz                                                     https://www.adafruit.com/product/3779 4‐3‐18
很抱歉,暂时无法提供与“3779”相匹配的价格&库存,您可以联系我们找货
