Purple Aluminum Chassis for TT Motors 2WD
PRODUCT ID: 3796
This royal undercarriage is made for the most noble, born in the purple robots!
This Aluminum Chassis in Blinka purple makes for an excellent robot body. It's a
single piece of bent 2mm thick aluminum, with a variety of holes, slots and
cutouts for mounting boards, sensors, and servos. The sides are notched to fit
two DC Gear 'TT' motors perfectly - you'll want to get four M3 or 4-40 screws in
about 24mm/1.0" to mount the motors. In the front you can screw on a ball
caster. You can build a very sturdy (and quite handsome!) little robot rover with
this metal frame.
It's made of aluminum so it's light and strong
The anodizing is quite attractive to boot
Can be used to build a 2-wheel or 4-wheel robot
Tons of mounting holes & slots!
You can drill and cut aluminum so it's easy to modify
Won't crack or break if it falls down the stairs (alright, it happens)
Remember, this is just the metal frame chassis! Motors, wheels, motor driver,
microcontroller, etc are not included!
You'll probably want to also pick up the following to complete the robot body.
Two DC Gearbox 'TT' Motors
Two 'TT' Motor wheels (we have a range!)
One ball caster
Then you will also need a microcontroller and motor driver that can drive the 5V
DC motors. We recommend one of the following
Adafruit DC Motor & Stepper Shield for Arduino
Adafruit DC Motor & Stepper FeatherWing
Adafruit DC Motor & Stepper HAT for Raspberry Pi
Adafruit TB6612 DC Motor driver (can drive two DC motors)
Adafruit DRV8833 DC Motor driver (can drive two DC motors)
Adafruit Crickit (there's various types)
A matching microcontroller or microcomputer is also required!
TECHNICAL DETAILS
Product Dimensions: 172.0mm x 90.0mm x 31.0mm / 6.8" x 3.5" x 1.2"
Product Weight: 115.6g / 4.1oz
https://www.adafruit.com/product/3796 6‐4‐18
很抱歉,暂时无法提供与“3796”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+131.768301+17.12667
