DIN Rail RJ-45 To Terminal Block Adapter
- Vertical Jack
PRODUCT ID: 3798
This one going out to all the makers and designers who use DIN railing in their
builds. This adapter plate was recommended by a customer, its perfect for
simplifying complex wiring. You connect an RJ45 cable (a.k.a Ethernet) to this
very PCB which can be DIN rail-mounted. Then, all 8 wires are broken out into
terminal blocks, so you can connect and power your sensors, displays,
microcontrollers, etc.
No soldering required! Just unscrew the terminal blocks and slide in your
stranded or solid-core wire.
Note that these aren't recommended for actual Ethernet traffic, especially long
term...given that the twisted pairs are decidedly untwisted when they are on the
PCB but for basic power/data distribution, RJ45's are great!
This is the DIN Rail RJ-45 to Terminal Block Adapter that comes with a Vertical
(Straight) RJ45 Ethernet jack on one end and terminal blocks on the other. We
also have a DIN Rail RJ-45 to Terminal Block Adapter - Right Angle
TECHNICAL DETAILS
Product Dimensions: 70.0mm x 45.0mm x 30.5mm / 2.8" x 1.8" x 1.2"
Product Weight: 30.4g / 1.1oz
https://www.adafruit.com/product/3798 6‐4‐18
很抱歉,暂时无法提供与“3798”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+142.442381+18.41897
