JST PH 2-Pin Cable – Male Header 200mm
PRODUCT ID: 3814
For a really long time we assumed that the JST PH didn't have a free-hanging male
header version. But then we found this JST-PH 2-pin Male Cable, and we were like, this
is perfect! It's not a genuine JST connector, but it's 100% compatible with a nice clicky
connection that you can undo without tearing the contacts from the housing.
Plugs in nicely all with our Li-Poly batteries, it even has the right color coding! What
more could you want?
We have the plug 'mating' version of this cable over here, as well as an 'extension' cable
that has one of each soldered together. If you want a switch in the middle, try this
switched extension cable. Finally, for PCB and breadboard use, we have the same
connector but on a PCB
For more information about JST PH connectors, visit the JST website
TECHNICAL DETAILS
Weight: 1.1g
Length: 20cm / ~7.9"
https://www.adafruit.com/product/3814 6‐12‐18
很抱歉,暂时无法提供与“3814”相匹配的价格&库存,您可以联系我们找货
