3829
3829
    ADAFRUIT
    PIMORONI NOISE:BIT FOR MICRO:BIT
3829 数据手册
    Pimoroni noise:bit for micro:bit PRODUCT ID: 3829 *HONK* *HONK* micro:bit comin' thru! Maybe you've played with the micropython speech module, or maybe you want to have MakeCode sound effects. Well, we couldn't let the other boards have all the audio fun! Now you can make your micro:bit BLURP and BEEP with noise:bit! Just slide noise:bit into the micro:bit board and start MakeCoding to your maker heart's content. Generate sound bites, tones, etc, with the sound generation blocks. Or, if you're more experienced and up for a challenge, you can experiment with MicroPython in the Mu code editor! Please note that the noise:bit is an amplifier not a synthesizer - the audio still comes from the micro:bit PWM output on pad #0. It's not going to get high quality audio reproduction but great for basic sound effects! Features      Comes fully-assembled and ready to use TPA301 amplifier chip 8Ω 2W Mylar speaker Compatible with micro:bit No soldering required! TECHNICAL DETAILS For product support, replacement parts and warranty for Pimoroni products, visit the Pimoroni forum or contact Pimoroni directly. Product Dimensions: 66.0mm x 38.0mm x 20.0mm / 2.6" x 1.5" x 0.8" Product Weight: 21.0g / 0.7oz                                                  https://www.adafruit.com/product/3829 6‐20‐18
很抱歉,暂时无法提供与“3829”相匹配的价格&库存,您可以联系我们找货
