3838
3838
    ADAFRUIT
    线束
3838 数据手册
     Arcade Button and Switch Quick-Connect Wires - 0.25" (10-pack) PRODUCT ID: 3838 Quick connector wire sets make wiring up our arcade-style or metal buttons quicky-quick. Each wire comes as a 'pair' with two 0.25" quick-connects precrimped. The wires are terminated together in a JST 2.5mm 2-pin connector. This connector will fit in 0.1" headers, so it's breadboard compatible or you can stick two wires into the end. Of course, you can chop this off if there's no use for it. If you need a connector for the other side, try this JST XH (matching part from Digi-Key here) https://www.digikey.com/products/en?x=0&y=0&lang=en&site=us&KeyWords=455-2247-ND We've found these work best with our:  Massive Arcade Buttons (will fit both the LED and switch contacts)  Large Arcade Buttons(will fit both the LED and switch contacts)  Micro Switch with Wire But they are not compatible with our smaller LED and mini arcade and buttons. For those, you'll want either the 0.11" Quick-Connect Wire pairs or the 0.187" Quick-Connect Wire pairs. TECHNICAL DETAILS Wire length (including connectors): 215mm / ~8.5"                                                    https://www.adafruit.com/product/38385 8‐6‐18
很抱歉,暂时无法提供与“3838”相匹配的价格&库存,您可以联系我们找货
    库存:13
