3845
3845
    ADAFRUIT
    小键盘开关 12 聚合物 钥匙 传导橡胶 触点 矩阵 输出 不发光
3845 数据手册
  3x4 Matrix Keypad PRODUCT ID: 3845 Punch in your secret key (or Jenny's number) into this numeric matrix keypad. This keypad has 12 buttons, arranged in a telephone-line 3x4 grid. The keys are connected into a matrix, so you only need 7 microcontroller pins (3-columns and 4-rows) to scan through the pad. Check the tutorials tab for links to an Arduino library and example code. We include some header so you can plug this into a breadboard with ease, some light soldering is required to attach it. Or you can use plain wires if you like. There's a great Matrix Keypad Arduino library that should work great with this item with minor adjustments. It's basically a sturdier version of our Membrane 3x4 Matrix Keypad. Note that the rows and columns are intermixed. The order from left to right is COL2, ROW1, COL1, ROW4, COL3, ROW2, ROW1 We also have a 4x4 version of this matrix keypad and a version that has phonestyling with letters printed over the numbers If you dig our demo, check out the Adafruit FeatherWing OLED - 128x32 OLED TECHNICAL DETAILS  Force: 160-180g  Contact Resistance:
很抱歉,暂时无法提供与“3845”相匹配的价格&库存,您可以联系我们找货
  • 1+60.869371+7.61716
库存:14
