3846
3846
    ADAFRUIT
    探头组件
    SENSOR DIGITAL -55C-125C
3846 数据手册
      High Temp Waterproof DS18B20 Digital Temperature Sensor - 3m long PRODUCT ID: 3846 This is a pre-wired and waterproofed version of the DS18B20 sensor made with a PTFE wire cable. Handy for when you need to measure something far away, or in wet conditions. This sensor is a little more expensive than the other waterproof version we have with a PVC cablebecause this one can be used up to 125°C - the limit of the sensor itself. That said, it's still not recommended for salt-water or corrosive environments since the stainless steel will eventually rust! Because the sensor signal is digital, you don't get any signal degradation even over long distances! These 1-wire digital temperature sensors are fairly precise (±0.5°C over much of the range) and can give up to 12 bits of precision from the onboard digital-to-analog converter. They work great with any microcontroller using a single digital pin, and you can even connect multiple ones to the same pin, each one has a unique 64-bit ID burned in at the factory to differentiate them. Usable with 3.0-5.0V systems. The only downside is they use the Dallas 1-Wire protocol, which is somewhat complex, and requires a bunch of code to parse out the communication. If you want something really simple, and you have an analog input pin, the TMP36 is trivial to get going. You'll need a 4.7k resistor which is required as a pullup from the DATA to VCC line when using the sensor. Here's a CircuitPython/Python guide for these sensors. We don't have a detailed Arduino tutorial, but you can get started by using the Dallas Temperature Control Arduino library which requires also the OneWire Library. TECHNICAL DETAILS Cable specs:  Stainless steel #316 tube 6mm diameter by ~30mm long (size of stainless steel capsule may vary!)  Cable is approx 3m long / 300cm long  Contains DS18B20 temperature sensor  Three wires - Orange Stripe connects to 3-5V, White connects to ground and Blue Stripe is data. DS18B20 Technical specs:  Usable temperature range: -55 to 125°C (-67°F to +257°F)  9 to 12 bit selectable resolution  Uses 1-Wire interface- requires only one digital pin for communication  Unique 64 bit ID burned into chip  Multiple sensors can share one pin  ±0.5°C Accuracy from -10°C to +85°C  Temperature-limit alarm system  Query time is less than 750ms  Usable with 3.0V to 5.5V power/data                                                       https://www.adafruit.com/product/3846 8‐20‐18
很抱歉,暂时无法提供与“3846”相匹配的价格&库存,您可以联系我们找货
