3856
3856
    ADAFRUIT
    MOTION CONTROL SCREWDRIVER
3856 数据手册
Motion Control Screwdriver PRODUCT ID: 3856 Description Doctor Who has the famous sonic screwdriver, and we have the next coolest thing, a Motion Control Electric Screwdriver! Ergonomic, comfortable to hold, and constructed out of stainless steel, it's a seriously exquisite hand tool with a ton of smarts that will make it your new favorite tool. Unlike most screwdrivers where you have to twist your wrist like a uncultured barbarian, this screwdriver has an IMU (inertial measurement unit) that can detect when you twist the tool left or right. Hold down the power button, and with the flick of your wrist, the screwdriver will automatically rotate in the direction you twisted! It's completely amazing, and we use ours every day now. This smart screwdriver also comes with an OLED screen that displays battery life and rotation mode. Perfect for when you're installing dozens of stand-offs onto your Crickit projects, or for when you want to feel like a powerful Time Lady or Time Lord from Gallifrey. Includes 1 x ES120 Motion Control Electric Screwdriver 2 x Bits - Flat & Philips 1 x Safety Instructions 1 x Luxurious Chamois Towel 1 x Carrying Pouch If you need a wider selection of bits, the screwdriver is also compatible with our 38-Piece Screwdriver Set Technical Details Body Material: 304 Stainless steel/Copper alloy 16x96 OLED screen Battery: 300mAh 10440 Lithium-ion battery Rotor: Bidirectional overrunning clutch Gearbox: 1:144 Integrated planetary gearbox Motor: 25,000 rpm brush motor Chip: STM32 Sensor: Angular velocity sensor Operation Voltage: 3-5V No-load Speed: ~170rpm Electronic Torque: 2.5kgf.cm Maximum Torque: 30kgf.cm (manual mode) Screwdriver Bit: 4mm hexagon Charging Time: 45 min Running Time: 30 min (full power) Charging Mode: microUSB 5V You can download and update the screwdriver's firmware. Product Dimensions: 131.0mm x 17.0mm x 17.0mm / 5.2" x 0.7" x 0.7" Product Weight: 108.0g / 3.8oz
很抱歉,暂时无法提供与“3856”相匹配的价格&库存,您可以联系我们找货
