3885
3885
    ADAFRUIT
    放大器 音频 STEMMA 平台评估扩展板
3885 数据手册
      Adafruit STEMMA Speaker - Plug and Play Audio Amplifier PRODUCT ID: 3885 Hey, have you heard the good news? With Adafruit STEMMA boards you can easily and safely plug sensors and devices together, like this Adafruit STEMMA Speaker - Plug and Play Audio Amplifier. Like the name implies, it's got a class D audio amplifier on board, and our favorite little 1 Watt 8 ohm speaker. Connecting it up is easy - you only need ground, 3 to 5V power, and audio signal. The audio signal does not need to be AC coupled, we do that for you, and can range up to the power pin voltage (3 or 5V peak-to-peak). You can use either the 3-pin JST socket or the alligator/sew-pads for this slim and portable package. The sound quality is good enough for music, tones, speech, whatever you like and volume can be adjusted with a small screwdriver. For use with a CircuitPlayground or micro:bit, this JST to alligator-clip cable works best. Red is power, ground is black and signal is white. For use with a breadboard, try this JST to male/plug-header. (We also have a socket-header cable if you want) TECHNICAL DETAILS  Assembled dimensions: 37mm x 30.5mm x 7.2mm Product Weight: 7.5g / 0.3oz                 https://www.adafruit.com/product/3885/9‐23‐19
很抱歉,暂时无法提供与“3885”相匹配的价格&库存,您可以联系我们找货
