Silicone Cover Stranded-Core Ribbon Cable - 10 Wire
1 Meter Long - 28AWG Black
PRODUCT ID: 3890
https://www.adafruit.com/product/3890#Slide5
DESCRIPTION
For those who are fans of our silicone-covered wires, but are always looking to up their wiring game . We
now have Silicone Cover Ribbon cables! These may look a lot like squid ink noodles, but they're not. The
silicone-sheathed wire is super-flexible and soft, and it's also strong! Able to handle up to 200°C and up
to 600V, it will do when PVC covered wire wimps out. We like this wire for being extremely supple and
flexible, so it is great for wearables or projects where the wire-harness has to be able to deal with a lot of
bending.
You get 1 meter of 10 x black wires, so you can pull and separate how many wires you need. The wire
is 28AWG stranded with an outer diameter of 1.2mm.
TECHNICAL DETAILS
Length: 1 meter / 39.3"
Outer Diameter (single wire): 1.2mm
Nominal Voltage: 600V
Temperature Range: -60ºC ~ 200ºC
OD Tolerance: ±0.1mm
Resistance: 220 Ω/Km
Product Dimensions: 1,000.0mm x 12.4mm x 1.2mm / 39.4" x 0.5" x 0.0"
Product Weight: 22.0g / 0.8oz
很抱歉,暂时无法提供与“3890”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+35.998031+4.64664
