3892
3892
    ADAFRUIT
    扁平带状电缆 黑色 4 导线 扁平缆线 3.28'(1000.00mm)
3892 数据手册
Silicone Cover Stranded-Core Ribbon Cable - 4 Wires 1 Meter Long - 26AWG Black PRODUCT ID: 3892 https://www.adafruit.com/product/3892#Slide5 DESCRIPTION For those who are fans of our silicone-covered wires, but are always looking to up their wiring game . We now have Silicone Cover Ribbon cables! These may look a lot like squid ink noodles, but they're not. The silicone-sheathed wire is super-flexible and soft, and it's also strong! Able to handle up to 200°C and up to 600V, it will do when PVC covered wire wimps out. We like this wire for being extremely supple and flexible, so it is great for wearables or projects where the wire-harness has to be able to deal with a lot of bending. You get 1 meter of 4 x black wires, so you can pull and separate how many wires you need. The wire is 26AWG stranded with an outer diameter of 1.5mm. TECHNICAL DETAILS • Length: 1 meters / 39.3" • Outer Diameter: 1.5mm • Nominal Voltage: 600V • Temperature Range: -60ºC ~ 200ºC • OD Tolerance: ±0.1mm • Resistance: 123 Ω/Km • Current Handling Capability: ~3.5 A (depends on length!) Product Dimensions: 1,000.0mm x 6.0mm x 1.3mm / 39.4" x 0.2" x 0.1" Product Weight: 13.5g / 0.5oz
很抱歉,暂时无法提供与“3892”相匹配的价格&库存,您可以联系我们找货
