3929
3929
    ADAFRUIT
    CANARY STAINLESS STEEL NON-STICK
3929 数据手册
      Canary Stainless Steel Non-Stick Cardboard Box Cutter PRODUCT ID: 3929 Cut through cardboard like butter with the Canary Box Cutter. This Japanesemade tool is perfectly engineered, way better than using scissors or a craft knife. This is the perfect tool for cardboard-crafting-trashbot enthusiasts! Ever get annoyed when your blade gets stuck to tape or adhesive? The Canary's fine sawtooth edge and non-stick coating take that problem out of the equation. The serrated double-edged blade makes it ideal for clean circular cuts. Its rounded chisel tip makes easy work out of peeling off stickers, making shallow cuts, or cutting packaging straps. If you're a maker-crafter who often works with cardboard, this is a necessary accesso TECHNICAL DETAILS  Overall Length: 190mm  Blade Length: 75mm  Materials:   Stainless Steel Blade  PP Plastic Handle Weight: 23.4g                                                         https://www.adafruit.com/product/3929 10‐4‐18
很抱歉,暂时无法提供与“3929”相匹配的价格&库存,您可以联系我们找货
