Adafruit NeoTrellis RGB Driver PCB for
4x4 Keypad
PRODUCT ID: 3954
By popular request, we've upgraded our popular Trellis elastomer button kits to
now have a PCB with full color NeoPixel support! You heard that right, no more
single-color LEDs, you can now have any color you like under the fantastic
rubbery button pads we sell.
These 4x4 button pad boards are fully tile-able and communicate over I2C. With
5 address pins, you've got the ability to connect up to 32 together in any
arrangement you like. With our trusty seesaw I2C-to-anything chip, you don't
even need to manage the NeoPixel driving. That's right! Both the button
management and LED driving is completely handled for you all over plain I2C.
With both Arduino/C++ and CircuitPython/Python library support, you can use
these pads with any and all microcontroller or computer boards.
Perfect for your next cool interface, MIDI instrument, control panel...whatever
could benefit from beautiful diffused colorful buttons. For fast connection to a
single board, we include a JST-PH 4-pin connector that will give you
power+data access. It's Grove compatible (the cable fits, even though its not the
exact same connector), or you can use a JST-PH 4 pin cable.
You can tile up to 32 boards together by soldering them edge-to-edge and
soldering closed the I2C address jumpers, then use one I2C connection
for all tiled NeoTrellis boards!
Each order comes with one NeoTrellis board with seesaw chip and 16 NeoPixels
already soldered in place. Elastomer button pad not included, so be sure to pick
one up!
TECHNICAL DETAILS
Dimensions: 60mm / 2.4" x 60mm / 2.4" x 4mm / 0.2"
This board/chip uses I2C 7-bit addresses
between 0x2E to 0x4D selectable by soldering jumpers on the back of the
board.
Product Dimensions: 60.0mm x 60.0mm x 7.5mm / 2.4" x 2.4" x 0.3"
Product Weight: 13.3g / 0.5oz
https://www.adafruit.com/product/3954 10‐2‐18
很抱歉,暂时无法提供与“3954”相匹配的价格&库存,您可以联系我们找货
