3961
3961
    ADAFRUIT
    可穿戴设备 导热胶带,卷材 缝纫 - 32.8'(10.0m)
3961 数据手册
    Conductive Nylon Fabric Tape - 5mm Wide x 10 meters long PRODUCT ID: 3961 With our fun assortment of conductive materials, cosplay and wearables have never been easier to craft! This Conductive Nylon tape goes great with our other interesting materials, such as copper tape, ITO glass or plastic, conductive inks, etc. We found that the metallic nylon fabric has some great improvements over plain copper tape.  First of all it doesn't crack when bent or twisted! So you can make all sorts of odd shapes and paths without worrying about broken traces. It's also more flexible so you can put it on a flexible material.      It comes with conductive glue on the opposite side, so you can tape it directly to capacitive pads.  It's high conductivity, only a few ohms per foot. It's not quite as conductive as pure copper tape, but you can definitely power small components.  But, you cannot solder to it like you can with pure copper tape. You can sew it though, since it's fabric. Each order comes with a strip of 5mm wide x 10 meter long tape. It's long enough you can use it for a bunch of projects. Just cut out the size you need and save the rest. If this tape isn't wide enough, we also carry it in 8mm! Please note the images above show the 8mm tape on the Circuit Playground board, this tape is a little narrower TECHNICAL DETAILS https://www.adafruit.com/product/3961 10-29-18
很抱歉,暂时无法提供与“3961”相匹配的价格&库存,您可以联系我们找货
