USB Mini B Female Socket to
5-pin Terminal Block
PRODUCT ID: 3969
TECHNICAL DETAILS
Terminal Block Pitch: 5mm
Product Dimensions: 30.0mm x 28.0mm x
10.5mm / 1.2" x 1.1" x 0.4"
Product Weight: 10.4g / 0.4oz
DESCRIPTION
Make your next custom USB cable a breeze with a USB Mini B Female Socket to 5-pin
Terminal Block. If you need to connect to a device with a mini USB plug or maybe make your
own USB OTG device or custom cable of sorts - this adapter will come in very handy: no
soldering required! Just use a small screwdriver to open up the terminal blocks, slide in
your stranded or solid-core wire, and re-tighten.
All the pins are labeled, which is really nice because we keep forgetting the order.
A – Pin 1 (V+)
B – Pin 2 (D-)
C – Pin 3 (D+)
D – Pin 4 (ID)
E – Pin 5 (GND)
We also carry the plug 'mating' version of this adapter.
很抱歉,暂时无法提供与“3969”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+53.30880
- 200+21.27600
- 500+20.56320
- 1000+20.21760
