USB Mini B Male Plug to 5pin Terminal Block
PRODUCT ID: 3971
DESCRIPTION
Make your next custom USB cable a breeze with a USB Mini B
Male Plug to 5-pin Terminal Block. If you need to connect to a
device with a mini USB socket or maybe make your own custom
cable of sorts - this adapter will come in very handy: no soldering
required! Just use a small screwdriver to open up the terminal
blocks, slide in your stranded or solid-core wire, and re-tighten.
All the pins are labeled, which is really nice because we keep
forgetting the order.
Terminal Block Pitch: 5mm
Product Dimensions: 34.0mm x 28.0mm x 10.4mm / 1.3" x 1.1" x 0.4"
Product Weight: 10.4g / 0.4oz
A – Pin 1 (V+)
B – Pin 2 (D-)
C – Pin 3 (D+)
D – Pin 4 (ID)
E – Pin 5 (GND)
We also carry the socket 'mating' version of this adapter.
很抱歉,暂时无法提供与“3971”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+57.488931+7.43773
