3984
3984
    ADAFRUIT
    探头组件
    RTD(电阻温度检测器) 铂(Pt) 探头组件
3984 数据手册
Platinum RTD Sensor - PT1000 - 3 Wire 1 meter long Product ID: 3984 Description For precision temperature sensing, nothing beats a Platinum RTD. Resistance temperature detectors (RTDs) are temperature sensors that contain a resistor that changes resistance value as its temperature changes, basically a kind of thermistor. In this sensor, the resistor is actually a small strip of Platinum with a resistance of 1000 ohms at 0°C, thus the name PT1000. Compared to most NTC/PTC thermistors, the PT type of RTD is much most stable and precise (but also more expensive) PT1000's have been used to measure temperature in laboratory and industrial processes, and have developed a reputation for accuracy (better than thermocouples), repeatability, and stability. This high-temperature PT100 sensor is equipped with a stainless steel shield that is good from -50°C to 280°C. PT1000 features:    Based on resistance measurement principles Resistor material is Platinum with a value of 1000 ohm at temperature 0°C Platinum has a positive resistance temperature factor; resistance increases with rising temperature   Resistance variation is a function of temperature: 3.85Ω/°C nominal High accuracy and stability compared to thermocouples, silicon-based temperature sensors, or thermistors Each sensor comes with three wires. Two of the wires connect to either side of the platinum resistor like you'd expect. The third wire is also connected to one end of the PT1000. If your RTD amplifier supports 3-wire sensors, it will drive the resistor with the first two wires, and measure the voltage differences so that it can subtract any voltage drop from the wires. If your RTD amplifier only has 2-wire support simply leave the third wire disconnected. Technical Details Cable specs:  316L Stainless steel capsule: 4mm diameter by ~30mm long (size of stainless steel capsule may vary!)  Cable is approx 1m / 100cm long  diameter is 2.8mm  26 AWG 7/0.15mm stranded  Contains PT1000 temperature sensor  Three wires with terminal prong ends https://www.adafruit.com/product/3984 11-18-22
很抱歉,暂时无法提供与“3984”相匹配的价格&库存,您可以联系我们找货
    库存:1000
