3990
3990
    ADAFRUIT
    电压计 模拟 - 黑色字符 显示 面板安装
3990 数据手册
          Large 5V Analog Panel Meter PRODUCT ID: 3990   Analog panel meters are arguably not as blingy or flashy as LEDs, but their simplicity adds a touch of elegance and makes them easier to read quickly. This Large 5V Analog Panel Meter is about handheld-size, with one screw to open up the panel and replace the backing paper, if you like. Even though it's designed for analog signals, you can use it with digital signals too! Simply send it a PWM signal from a 5V logic microcontroller. As long as you use 1KHz or faster, you'll be golden. The back is constructed with two bolts with Positive and Negative marked below the coils. You can wrap a wire around the bolt and use the nuts to keep them in place, or use alligator clips.     TECHNICAL DETAILS Panel Dimensions: 100 x 80 x 14.2mm                                 https://www.adafruit.com/product/3990 12‐3‐18
很抱歉,暂时无法提供与“3990”相匹配的价格&库存,您可以联系我们找货
