Ultrasonic Distance Sensor - 3V or 5V HC-SR04 compatible - RCWL-1601
PRODUCT ID: 4007
If you're like me, you've dreamed of being a dolphin - smoothly gliding through
the water. Using your echo-location abilities to detect tasty fish treats. Until
genetic modifications catches up with our desires, we'll just have to make do
with these handy 3V Ultrasonic Sonar Distance Sensor and a pair of flippers.
These ubiquitous sensors are really common in robotics projects, but they can
also be used for automation, interactive art and motion sensing. They work at
about 2cm to 450cm away, but we think 10cm-250cm will get you the best
results.
These sensors are fast, fairly easy to use, and low cost. Unlike the more
common HC-SR04 series, this model can be powered by 3V or 5V and the logic
level will be the same. This makes this model great for use with just about any
microcontroller or microcomputer. And, its HC-SR04 compatible so just drop it
in and it works the same!
If you need a version that also works with 3.3V power and logic, and has a
UART output as well as temperature reading, check out the US-100!
If you want the tried-and-true 5V-only HC-SR04 we have that in stock
here.
You can use this sensor with Arduino, CircuitPython (for microcontrollers or
Raspberry Pi) or MakeCode
We carry a large variety of distance sensors here if this fellow isn't what you're
looking for.
TECHNICAL DETAILS
Voltage: 3V - 5.5V
Current: 2.2mA
Measuring Range: 2cm - 450cm
Working Temperature: 0ºC to 70ºC
Compatible with HC-SR04 Ultrasonic Sonar Distance Sensor
Product Weight: 6.0g / 0.2oz
https://www.adafruit.com/product/4007/1‐23‐19
很抱歉,暂时无法提供与“4007”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.921461+4.51803
