4029
4029
    ADAFRUIT
    缆线组件 矩形 04 位(STEMMA)转鳄鱼夹(4) 0.63'(190.5mm)
4029 数据手册
      JST PH 4-pin Plug to Color Coded Alligator Clips Cable PRODUCT ID: 4029 This cable will let you turn a JST PH 4-pin cable port into 4 individual wires with grippy mini alligator clips. We're carrying these to match up with any of our boards or breakouts with 'STEMMA' connectors on them such as the HalloWing or NeoTrellis M4. Can also be used with any STEMMA breakouts! This cable has a JST PH 4-pin on one side and alligator clips on the other, so it could be used to connect to wires or pads like that on the Circuit Playground or micro:bit.  Black for GND  Red for V+  White for SDA  Green for SCL For more information about JST PH connectors, visit the JST website TECHNICAL DETAILS  Wire Length: 7.6" / 195mm  Wire Diameter: 1.6mm  JST Connector: 8.5mm  JST Pitch: 2mm                                       https://www.adafruit.com/product/4029/1‐17‐19
很抱歉,暂时无法提供与“4029”相匹配的价格&库存,您可以联系我们找货
