Vertical Breadboard-Friendly 3.5mm
Mono Headphone Jack
PRODUCT ID: 4031
DESCRIPTION
Pipe audio in or out of your project with this very handy breadboard-friendly
audio jack. It's a mono jack with a disconnect pin so you'll get a ground sleeve
pin, a left tip pin and a pin that will be disconnected when a jack is inserted.
You can use any 3.5mm audio cable with this jack. The pins are on 0.1" spacing
so it plugs very solidly (and vertically!) into a breadboard, perma-proto or perfboard. Works best if soldered into a perf-board but does work in a solder-less
one
Each order comes with one headphone jack. Breadboard and audio cable not
include
TECHNICAL DETAILS
Dimensions: 18 x 13.5 x 9mm
Product Weight: 1.0g / 0.0oz
https://www.adafruit.com/product/4031/1‐8‐19
很抱歉,暂时无法提供与“4031”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.66600
- 200+3.74760
- 500+3.60720
- 1000+3.54240
